63 fan shroud - NCRS Discussion Boards
63 fan shroud
  • Michael G.
    • November 12, 2008
    • 2158
    63 fan shroud
    Can anyone tell me what the gloss level of the black paint on a 63 radiator shroud should be?
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 63 fan shroud
    JG calls for gloss to semi gloss.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Michael H.
      • January 29, 2008
      • 7477
      Re: 63 fan shroud
      The entire shroud (minus rubber seal) was dipped in thin semi flat/gloss black. The results may be slightly more glossy than semi because of the fact that it was dipped. If it were sprayed with the same paint, it would be more on the semi flat side. Any semi flat/gloss should do it.
      Definitely not gloss, ESPECIALLY gloss black from a typical hardware store spray can, which contains very little pigment and a lot of clear/binder..
