54 gas tank - NCRS Discussion Boards
54 gas tank
  • Lynn L.
    1953-55 Team Leader
    • February 1, 2000
    • 162
    54 gas tank
    I need to replace my 54 fuel tank and I have not found a repro. Will a C2 tank fit? Any other recommendations to replace tank?
  • Mike M.
    • May 31, 1974
    • 8400
    Re: 54 gas tank
    i got a repo tank for my 55 just a year or two ago, got it from gary at Quanta. superb repo.mike
      • 43248
      Re: 54 gas tank
      Lynn-----
      There's no way that a C2 fuel tank could be used.
      Quanta only shows fuel tanks for 1956 and later C1 Corvettes. I do not understand that as I thought that, functionally, the C1 fuel tanks were interchangeable. But, I'll leave it to the C1 guys to pass judgement on that.
      • Randy G.
        • April 1, 2006
        • 358
        Re: 54 gas tank
        I had a repro on order for my '54 from Corvette Central for six months before they were told by their vendor that they would no longer be reproducing them. From what I understand many prefer to use a '57 repro tank (which is available) because it has baffles in it. You need to have the fitting on the bottom passenger's side installed in order to connect up the original design fuel lines. I also installed an inline fuel filter under the tank below the fitting.
        • John S.
          • July 29, 2009
          • 640
          Re: 54 gas tank
          i checked on 53-55 gas tanks a couple of months ago and grossmueller offered a stainless one. i think i was quoted $800.
          • Bruce B.
            • May 31, 1996
            • 2930
            Re: 54 gas tank
            Rock Valley Antique Auto makes a stainless steel tanks for 53 to 62 Corvettes.
            A friend with a 54 used a Quanta 56-57 Corvette tank which fit after some minor bending of the flange. A cheap way to get a new tank in a 54.
            • Lynn L.
              1953-55 Team Leader
              • February 1, 2000
              • 162
              Re: 54 gas tank
              Thanks for recommendations, Sorry for C2 reference, ment later C1 tank
              • Chris S.
                • January 1, 2000
                • 1068
                Re: 54 gas tank
                use a 56 57 repro tank
                works perfect
                the wires to the sender will reach.
                I one - non vented
                Hope this helps
                1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                1957 Corvette - FI 3 sp - Black and Silver
