Ques on making my own anti squeak pads - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 954
    Reading some past threads, I have decided to make my own anti squeak pads for under my fuel tank and tank straps from 30# roofing felt.
    I will glue a few layers together to roughly .100" thickness. Does anyone know the L x W dimensions for the pads under the straps as well a s the pads under the tank?
    Pat
    68 427 / 400
    88
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Ques on making my own anti squeak pads
    Pat, If you want it to look correct for judging the GM assembly only used one layer. Heavyest weight felt roofing does look very much like the original. That is what I use.
    • Alan D.
      • January 1, 2005
      • 2046
      Did same however found some material 1/8" which was my thickness, C2
      • Patrick N.
        • March 10, 2008
        • 954
        Thanks guys,
        Gene, I have read similar feedback and that 90# felt was very close to original but hard to locate. I have 30# paper and under the impression that I should glue a couple layers together. Seems .100" was the target give or take.
        Alan & Gene, do either of you know the dimensions for the pads? I am finishing the second strap right now but hope to do the pads later today.
        Thanks again,
        Pat
          • 43247
          Pat
          68 427 / 400
          88
          Patrick------
          Dr. Rebuild has done a very good job of reproducing these anti-squeak pads. They cost about 4 bucks for the pair. So, why mess around with making your own?
          • Alan D.
            • January 1, 2005
            • 2046
            The C2 where 1 11/32 wide X 18 thick however Joe makes a logical point!
            • Gene M.
              • April 1, 1985
              • 4232
              Thanks guys,
              Thanks again,
              Pat
              Pat,
              I think the heaviest (90# sounds right) is what I used. Now if I recall correctly the strips were about 2 inches wide. As to the length I just made then longer, glued them to the tank and cut off the excess. About 1 inch over hang to the tank on each end.
              • Patrick N.
                • March 10, 2008
                • 954
                Hi Joe et all, I was under the impression that roofing felt was basically what the pads were made of and I have plenty of that to simply cut and glue my own.
                Honestly though, I was not aware that anyones pads were good. I bought a pair for under the tank a while back from another good soucre and really shocked that not only did I pay too much for roofing felt, the pads were a paper thin. After reading some threads, seemed like making your own was the way to go, especially if I have the material.
                $4 bucks from the Dr seems like a good way to go now however.
                Pat
                • Larry M.
                  • January 1, 1992
                  • 2701
                  Patrick------
                  I agree. That is what I used. Very satisified.
                  Larry
