66 Shifter - NCRS Discussion Boards
66 Shifter
  • Ralph B.
    • July 30, 2008
    • 178
    66 Shifter
    Need your help:
    1. What date or S/N did the 66 shifter mount change over from transmission mount to frame mount?
    2. I have an original 69 shifter, can this be used on my 66 ? or are there differences?
    Thank you,
    Ralph
  • David L.
    • July 31, 1980
    • 3310
    Re: 66 Shifter
    Ralph,
    My 1966 Corvette (Feb. 1966) came with the 3888263 bracket as shown in the AIM (UPC 6, sheet B6). The date on the Muncie 4-speed transmission is "P0211" (Feb. 11, 1966).
    I believe that you can use your 1969 shifter.
    Dave
    • Michael H.
      • January 29, 2008
      • 7477
      Re: 66 Shifter
      Originally posted by Ralph Benedetti (49275)
      Need your help:
      Thank you,
      Ralph
      A GM TSB shows a date of 21 March 1966 for the change to a crossmember mounted shifter.
      I think quite a few early production cars were changed over to the new design in service because of complaints of shifter buzz.
        • 43289
        Re: 66 Shifter
        Need your help:
        Thank you,
        Ralph
        Ralph-----
        The 1964-67 and 68-76 Corvette shifters are functionally the same EXCEPT for the shifter lever. The 1969 shifter lever will not orient exactly correctly in the shifter opening in the mid-year console. Also, as I recall, the lever lengths are slightly different.
        However, the 1968+ shifter assembly will work for a mid-year. In fact, GM cataloged the 68+ assembly for 64-67 SERVICE. It just won't be "exactly right".
        Can you swap out the lever from a 1964 shifter assembly with one from the 1969 assembly? Yes, you can. However, understand that the "blade" which is an integral part of the lever (at the bottom) is critical for a properly functioning shifter. If the blade is worn, the shifter is not going to work right.
        • David L.
          • July 31, 1980
          • 3310
          Re: 66 Shifter
          Since the bulletin is dated June 13, 1966, and it states that "all Corvettes produced after the date 3-21-66 are equipped with the crossmember mounted gear shift control assembly" then my 1966 Corvette (body build date Feb.24, 1966) must have been changed sometime between 1966 and 1979 when I bought it. It did not have the original engine when I bought it but the transmission, flywheel, fan-clutch, and alternator were original based on the date codes and partial VIN on the transmission.
          • Gary B.
            • February 1, 1997
            • 7080
            68+ Shifter; 77-82?
            Joe,
            Somehow I got the impression that the 68-76 shifter could also be used for 77-82. Is this incorrect?
            Gary
            • Wayne M.
              • March 1, 1980
              • 6414
              Re: 66 Shifter
              Originally posted by David Liukkonen (3775)
              Since the bulletin is dated June 13, 1966, and it states that "all Corvettes produced after the date 3-21-66 are equipped with the crossmember mounted gear shift control assembly ....
              Related question: since the mod's described in the TSB involved drilling two 9/32" holes in the back face of the crossmember, for two 5/16" self-tapping screws (for dealer or owner modification on cars produced prior to 3-21), was the frame modified sometime prior to this date by the supplier so that this additional operation would not be necessary on the assembly line ?
                • 43289
                Re: 68+ Shifter; 77-82?
                Originally posted by Gary Beaupre (28818)
                Joe,
                Gary
                Gary------
                The 1968-76 shifter was never cataloged by GM as a replacement for the 77-81 after the latter was discontinued. Once again, the shifter lever was different for the 1968-76 and 77-81. Could the 68-76 be used for 77-81 (and vice-versa)? I don't know.
                  Re: 66 Shifter
                  Wayne -
                  I'm sure it was - the shifter bracket and attaching parts were released and added to the A.I.M. sheet eight months prior to the change actually being implemented on the line at St. Louis, so there was plenty of time for the A.O. Smith frame plant to add the two holes in the back wall of the crossmember.
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    Re: 66 Shifter
                    Something that may be a hint as to the originality of the bracked may be it's attaching bolts. If dealer installed, I would guess that the bolts are just typical hardware store type. I don't remember what the correct assembly line bolts were though. Possibly washer head??
                    • Gary B.
                      • February 1, 1997
                      • 7080
                      Re: 66 Shifter
                      Joe,
                      Is there any easy way to visually distinguish between a 68-76 shifter and a 77-81 shifter?
                      Gary
                      • David L.
                        • July 31, 1980
                        • 3310
                        Re: 66 Shifter
                        When I did my frame-up restoration from 1980 to 1995 I believe that I reused the original bolts for the shifter bracket. I have that information in my restoration records as I kept track of all minor details like bolt markings, etc. When I get a chance I will go to the archives.
                          • 43289
                          Re: 66 Shifter
                          Joe,
                          Gary
                          The shifter lever on the 77-81 shifters is 7/8" longer than that used on the 68-76 shifter.
                          • Gary B.
                            • February 1, 1997
                            • 7080
                            Re: 66 Shifter
                            Thanks Joe. And I know the 68-76 shifter was longer than that the 63-67 shifter.
                            Gary
                              • 43289
                              Re: 66 Shifter
                              Michael-----
                              The original screws were flanged, hex head and of 5/16-18 thread size and 3/4" length. They were phosphate-finished.
