Gear, Transmission Speedometer - NCRS Discussion Boards
  • Michael S.
    • August 31, 1985
    • 75
    What would be the rear end ratio for a orange gear with 25 teeth.
    Thanks, Michael
    • 43219
    Re: Gear, Transmission Speedometer
    Thanks, Michael
    Michael-----
    It varies a bit depending upon year model and specific application but, in general, the 25 tooth orange DRIVEN gear is used with 3.70:1 or 4.11:1 rear gear ratios.
      • 6941
      Mike, you may have to post alittle more info, 4spd,auto, is this the drive gear inside trans or driven gear in the housing thats orange?year or car also
      • Michael S.
        • August 31, 1985
        • 75
        It's a NOS part that I never used. It goes inside the side of the 4-speed. I looked it up in the GM Parts book which told me it's for a 1967 corvette w4:10 ratio. The Part # is 3860347
        Thanks, Michael
        • Wayne M.
          • March 1, 1980
          • 6414
          Thanks, Michael
          Michael -- are you sure of color ? In my parts book, 3860347 is a yellow, 24-tooth driven gear, usually found in C2's with 4.11 final drive.
          • Michael S.
            • August 31, 1985
            • 75
            Wayne, I can send you a picture.
              • 43219
              Thanks, Michael
              Michael-----
              It's applicable to 4 speed as well as 3 speed manual transmissions. It's not unique to 1967 Corvettes by any means. It's applicable to virtually all Chevrolets of the period.
                • 43219
                Thanks, Michael
                Michael------
                If the gear is orange and 25 teeth but the package says GM #3860347 on it, then either it was mis-packaged (if the package seal is unbroken) or someone switched it (if the package seal is broken). The GM #3860347 is a yellow, 24 tooth gear. The orange 25 tooth gear is GM #3860348.
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  Here's a shot of the orange 25-tooth. Does look a little "yellow-y".
                  • Michael S.
                    • August 31, 1985
                    • 75
                    Here's what I have
                    • George C.
                      • November 1, 2001
                      • 568
                      Wayne,
                      Can I have the parts in your photo? I bet I could get my speedometer to work correctly with that assortment.
                      I believe my car was originally equipped with a 4.11 gear; it is now sporting a 3:36. So I read about 17% low on the speedometer.
                      I am planning to remove the transmission this summer, change out the drive gear, and get the correct driven gear installed.
                      George
                        • 43219
                        Here's what I have
                        Michael------
                        If that gear has 25 teeth on it and I fully expect it does, if it originally was supplied in that box then it was mis-packed. However, I doubt that happened. Much more likely someone took it out of another box and put it in that box. The part number of the gear pictured is 3860348.
