'61 Bumper Alignment Help - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    I put my bumper back on after paint a few months ago and noticed that the rt side hangs lower by the upper eye brow. It lined up perfectly before disassembly. I believe I replaced the grille bar with a repo. Based on the photo where does the adjustment need to be made? Thanks
  • Mike M.
    • May 31, 1974
    • 8408
    Re: '61 Bumper Alignment Help
    loosen ALL bracket to frame and bracket to bumper bolts. the pass side inner needs raised and the drivers side inner needs lowered by exerting forces on the inner aspects of the bumpers(get two buddys to do the forceful movements of the bumpers while you re-tighten the multiple bolts. good luck,mike
