1966 Vacuum advance can - NCRS Discussion Boards
  • Larry M.
    • March 1, 2002
    • 62
    What is the correct vacuum advance can for a 1966 327-300hp powerglide wo/air? Thanks for any info. Larry....
    • 43290
    Re: 1966 Vacuum advance can
    Larry-----
    GM #1115355. This is long since GM discontinued. A functional replacement can be obtained under Delco #D1310C or NAPA/Echlin VC1765. They will be stamped B20 or B26.
    • Ronald L.
      • October 18, 2009
      • 3248
      LIC should have a visually close match, see the posts from last year about whether they are calibrated as OEM...
      • David L.
        • July 31, 1980
        • 3310
        Larry,
        You can usually find NOS 1115355 vacuum controls on Ebay but be prepared to open your wallet. I assume you have a 1111153 distributor.
        Dave
