Hello experts,
I am assembling my engine and although I'm a long way from being able to start it I would still like to do as much assembly as I can while the body is off.
The problem (or not) is that the coil bracket is hard against the vacuum can of the distributor. The rotor is aligned on the #1 plug wire tower. I can rotate the distributor CCW which takes the vacuum can away from the coil bracket, but I won't be able to rotate it CW. If I move the coil bracket more towards the rear of the car to get clearance the ground clip on the top ignition cover doesn't touch the FI plenum. Do I have a problem here or am I missing something?
I also am afraid that the oil line to the distributor will prevent the rotation of the distributor. Does the line get removed and plugged temporarily while timing is set, then bent so it reaches on both ends?
Thanks-Doug
Thanks-Doug
