Removing Chrome - NCRS Discussion Boards
Removing Chrome
  • Joe M.
    • April 30, 1990
    • 1338
    Removing Chrome
    I believe the seat belt hambones were installed prior to body painting and therefore, should be body color. What type of acid is required to remove the chrome off of the repro hambones? Or is this a DIY project?
    • 6950
    Re: Removing Chrome
    Joe, If you lightly scuff the hambones with a fine sandpaper and use a self etching primer the paint will have a good chance to stick to the chrome.
    • Gerald C.
      • June 30, 1987
      • 1299
      Re: Removing Chrome
      Joe,
      Did you try Ed's option and if so, how did they come out?
      Jerry
      • John D.
        • December 1, 1979
        • 5507
        Re: Removing Chrome
        Let a chrome plating shop strip the parts in a few minutes
        • Joe M.
          • April 30, 1990
          • 1338
          Re: Removing Chrome
          I don't remember what I chose to do in 2011.
          • Ken R.
            • August 31, 1980
            • 308
            Re: Removing Chrome
            I just used a buffing wheel and some rouge and took off the chrome on some SS trim pieces I had. You would need to rough up the surface for a primer to stick then.
              • 43247
              Re: Removing Chrome
              Joe------
              Hydrochloric (muriatic) acid will remove the chrome. Be very careful using this. Wear gloves and eye protection.
              • Tracy C.
                • July 31, 2003
                • 2739
                Re: Removing Chrome
                Joe------
                You are correct Joe. A 5 minute swim in a 50/50 mix with acid/tap water will do the trick. The nickel will remain on the part but will be etched enough for paint to stick. Also neutralize the acid on the parts by rinsing them in water with baking soda mixed in. This will prevent surface rust from forming on the part. Otherwise the acid will continue to work on the surface of the parts even when you think it is completely rinsed off. 1/2 pound soda in 2 gallons of water is adequate. You can also use this water/soda solution to kill the acid prior to disposing as hazardous waste.
                tc
                • Mike E.
                  • February 28, 1975
                  • 5141
                  Re: Removing Chrome
                  Your initial premise that they should be painted is faulty. In unrestored cars I have seen them unpainted and partially lightly dusted, but never fully painted.
