Comparing original vs. repro 63-65 327 oil caps - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    Re: Comparing original vs. repro 63-65 327 oil caps
    Originally posted by Doug Loeffler (51544)
    The cap on my engine was original. It had to be because it was soo crappy looking and because John DeGregory told me it was when he received it with my FI unit. I had it replated and it came out very nice. I don't have a repro to compare it with but in the attached photo the dimple is very evident. I was under the impression that some repro don't have the dimple.
    Doug
    Hi Doug, Your oil cap looks very nice. I have never been able to have a oil cap with a dimple sucessfully replated. I have put notes and told the plater over the phone. But still the caps come back minus the dimple.
    Yours is quite impressive. JD
    How about another post Doug showing the gang your flat washer on the fuel filter stud.
    • David L.
      • July 31, 1980
      • 3310
      John,
      How can the dimple be removed in the replating process?
      Dave
      • John D.
        • December 1, 1979
        • 5507
        #18
        David, The platers buff it off somehow.
        Saw your nice ad on ebay with the oil caps. Great photos. Thanx, JD
        • David L.
          • July 31, 1980
          • 3310
          #19
          John,
          I think it would be easier to chrome plate the black phosphate caps. I believe you could easily buff off the black phosphate with a wire wheel to get down to bare steel without any metal removal. The platers must use something very coarse to grind off the old chrome and end up removing a lot of metal.
          Dave
          • Ronald L.
            • October 18, 2009
            • 3248
            #20
            On a replate or first time thru, they hit these with acid, no need to worry about what is there - it will be gone.
            My experience is they want to buff the daylights out of everything. Take all the flaws in ignition shielding, they don't like to do a job that leaves all the stamping die draw scratches, nicks and wrinkles in there.
            SO they buff away with seriously aggressive abrasives...
            • John D.
              • December 1, 1979
              • 5507
              #21
              Originally posted by David Liukkonen (3775)
              John,
              Dave
              David, The black phophate caps I bought in the late 70's and early 80's were not the same configuration. JD
              • David L.
                • July 31, 1980
                • 3310
                #22
                John,
                As you can see in my photos on my first post on March 21st the black phosphate cap was the same as my NOS chrome cap. I have 2 of these black caps (GM 3714893 and they came in blue & white GM paper wrappers with clear on the back side. I can not remember when and where I got them.
                Dave
