63 fuel pump mounting plate - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2157
    Is the fuel pump mounting plate engine orange, or something else?
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Chuck W.
    • May 31, 2002
    • 257
    Re: 63 fuel pump mounting plate
    I believe it is natural.
      Chuck -
      I agree - virtually all I've seen have been natural. Hundreds of raw iron and steel parts were received in the plant, and only those shown on the "Painted Parts List" were paint-processed in the plant prior to delivery to the line.
      The "Painted Parts List" was issued by the Chevrolet-Central Office Paint Standards Department to the Paint Superintendents at each plant, describing each part that was to be painted, and how each one was to be processed. Unfortunately, those were internal documents, and none have survived as references; we have to depend on observations of known-original cars in order to make judgments on finishes as-shipped from the plant.
        • 43248
        Michael-----
        I agree with John and Chuck. These plates, installed at St. Louis, were natural steel. I think that GM figured there would be enough oil leakage from the engine to coat the plate and "permanently" protect it from corrosion. If that's what they figured, they almost invariably got it right.
        • Philip C.
          • December 1, 1984
          • 1117
          Chuck -
          Hi John do you remember the time frame you saw those pump plates, Thanks Phil 8063
            Phil -
            I remember them rolling down my Engine Dress Line when I was a Production Foreman at Willow Run in 1964 (when I started at GM), and for many years thereafter.
            • Michael G.
              • November 12, 2008
              • 2157
              Thanks Guys,
              I had one natural and one painted, so I was confused a bit. Luckily, the the car with the natural one was not being worked on and the painted one was already off of its engine for refinishing.
              Mike
