63 fuel pump mounting plate - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2157
    Is the fuel pump mounting plate engine orange, or something else?
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    Re: 63 fuel pump mounting plate
    Let's see if you can answer this!
    Is the fuel pump called out for assy to the engine in your copy of the AIM? That means it was installed at St. Louis and not at the engine plant in Flint/Tonawanda. By the time the core engine assy reached St. Louis it was already painted...
    The engine plants test fired engines using propane vs. gasoline. Therefore, they didn't need to have carb's and fuel pumps present to start/run.
