1965 corvette Big Block Negative Battery Cable - NCRS Discussion Boards
  • Brenton M.
    • May 31, 2006
    • 66
    Where does the Battery ground cable connect on a 1965 corvette 396/425. I have it on the engine block, I was told it went on starter.
    HELP!!!
  • Marco H.
    • March 1, 2002
    • 218
    Re: 1965 corvette Big Block Negative Battery Cable
    Brenton,
    since your battery is located on the driver side, the negative cable goes to the bell housing. (You should have 2 j-hooks very close together, below, near the column mount.) Your cable should be routed from the battery post through the lower of the 2 j-hooks and from there to the bell housing. (the upper j-hook is used for the positive cable.) Check the AIM for reference.
    Hope this helps.
    Marco
    • Wayne M.
      • March 1, 1980
      • 6414
      Originally posted by Marco Hartner (37619)
      ..... from the battery post through the lower of the 2 j-hooks and from there to the bell housing. (the upper j-hook is used for the positive cable.) Check the AIM for reference. ....
      Might add that the AIM reference is found in the air conditioning [C60] section, which is essentially the same as for the L78, with respect to many firewall area items.
      Then the question is "to which bellhousing bolt does the ground cable connection attach" ? Looking at the AIM (C60), it seems to point to the lower of 2 bolts on the driver side; the one just above the clutch fork rod. But when you come to install, it aligns more easily to the top bolt, for both air and BB cars. Opinions welcome .
      • Daniel K.
        • April 1, 2002
        • 190
        As Wayne has indicated above for the connection. Dan K.
