question on timing light snap-on MT2261 - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    I was able to purchase a snap-on timing light model MT2261 . Tach/adv It didn't come with operating instructions. Just wondering if anyone might have the same timing light with instructions. Thanks
  • Bob H.
    • July 31, 2000
    • 821
    Re: question on timing light snap-on MT2261
    I guess Snap On wants to sell them only.
    Reset button - resets the light to zero
    Tach/Adv - Toggles between the tach setting and the advance settings.
    Flash - On/Off for the strobe
    Dec - Decrease the setting
    Inc - Increases the setting
    Basic use. Hook up the battery leads, Clip the pickup on cylinder number
    one. It should come up and ask you to select number of cylinders.
    Now it will display the rpms of the engine and can be used as a standard
    timing light.
    To use the advance feature you need the specs for the engine. They will
    tell you that base timing should be something like 4 degrees at 500 rpm.
    and that full advance should be something like 30 degrees at 1500 rpms.
    Now use the Tach/Adv button to select degrees. Use Dec/Inc to adjust
    that number. Then switch to tach and adjust it to the correct number.
    When you use the light set properly it will read zero degrees at the set
    rpm IF the timing is correct. Use the same thing to check full advance.
    • Wayne P.
      • January 23, 2008
      • 444
      Great thanks Bob
      • Gary C.
        Administrator
        • October 1, 1982
        • 17768
        Wayne, you have an email. Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Wayne P.
          • January 23, 2008
          • 444
          yes I sent it to you thx
