'66 L79 crank pulley; faking "Parkolac" - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7054
    Re: '66 L79 crank pulley; faking "Parkolac"
    Originally posted by Ronald Lovelace (50931)
    Gary,
    No answer yet, but before we decide that the alternate coatings circle 3 and circle 4 are appropriate for 1966, we need to know the date they were added to the print.
    Ronald,
    I understand. Is it possible to find the dates that those notes were added to the GM document?
    Gary
      Gary
      Gary -
      Yes - if someone has the full print, it'll be in the revision block.
      • John D.
        • June 30, 1991
        • 875
        john
        The optional coating: phosphate plus spray coat with BF Goodrich A-1256-B black rubber resin base or equivalent to a 0.0004 minimum was added to the drawing on 10-18-68.
        An underbake test specification that 5 drops of ketone on a rag should yield no transfer of coating was also added at that time.
        john
        • Gary B.
          • February 1, 1997
          • 7054
          Originally posted by John Daly (19684)
          john
          john
          John,
          Do you know the date for the Parkolac coating? Presumably that pre-dates the rubber resin option.
          Gary
          • John D.
            • June 30, 1991
            • 875
            gary
            It appears to be part of the original spec when the part waqs drawn in december 63
            • Gary B.
              • February 1, 1997
              • 7054
              That would mean the only coating post-phosphating on these pulley from '63 until Oct '68 was the Parkolac.
              So, back to question # 1. How can one fake parkolac?
              Gary
              • Gary B.
                • February 1, 1997
                • 7054
                PS. I guess this also means the the "rubber resin" language in the latest edition of the '66 TIM&JG may need to be removed.
                Gary
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  Gary,
                  I talked to Parker Chem (Henkel now adays).
                  What we need to be completely sure of the composition, is to get the old MSDS sheet for Parkolac 30. They don't have that since it was discontinued many years ago. Expecting that a base family of coatings use essentially identical ingredients, I asked about the Parkloac 2945 that was discontinued last year. It was a water diluted coating that in the notes they found references to application over black oxide. Now, if it was a wash solution over black, you would not pick up the brown color too much. It dried tack free by air. The reason it was discontinued last year was due to the base ingredient no longer being made.
                  Off hand I don't have a source for old MSDS sheets, we'll keep looking.
                  • Gary B.
                    • February 1, 1997
                    • 7054
                    #24
                    Ron,
                    Thanks for checking into this. I appreciate the information.
                    Gary
