1979 Shock Label Decals - NCRS Discussion Boards
  • Schanen C.
    • February 1, 2010
    • 122
    Hello All,
    Which Labels are Correct for 79 with standard Suspension???
    EM EK Em El ???
    And where i can find the correct Spring decals ??
    Who can Help me Please.
    Thanks.
    Rgds.
    Carlo
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 1979 Shock Label Decals
    Schanen the codes should JX and JY for a standard suspension shock. I have not kept up with which supply house are making shock labels but you could try Corvette Central or Paragon. But you can make them at home on your computer using return address labels.
    Paul 18046
    • Paul O.
      • August 31, 1990
      • 1716
      Schanen disregard my earlier post the info I used was out dated and code maybe different then I listed. Sorry.
      Paul 18046
      • Tom R.
        • June 30, 1993
        • 4102
        Originally posted by Schanen Carlo (51311)
        Hello All,
        EM EK Em El ?
        Hey Carlo
        1979 called out the same shock part numbers as 1978 for base suspension and those broadcast codes were CH (front) and CJ (rear).
        Build sheets I have confirm that the same broadcast codes for either year called out CK and CE for the FE7 suspension in 79 but don't have build sheets for 79 base suspension.
        But I'm curious how you came up with the EM, EK, etc?
        Tom Russo
        78 SA NCRS 5 Star Bowtie
        78 Pace Car L82 M21
        00 MY/TR/Conv
