1963 360 Hp Valvecover Decal - NCRS Discussion Boards
  • Tom R.
    • December 20, 2010
    • 177
    I have seen two types of decals offered for the L84. One is a peel and stick metallic-looking decal and the other a waterslide decal that is not metallic at all. My AIM doesn't distinguish that I can tell, although it calls for a "Decalcomania" whatever that is. Which one is correct?
    • 43273
    Re: 1963 360 Hp Valvecover Decal
    Tom-----
    The "waterslide" decal is the one originally used. This is the type that's referred to as "decalomania".
    • Tom R.
      • December 20, 2010
      • 177
      Tom-----
      Then Joe, that's what I'm using. Thanks, I thought that was the answer but wanted to make sure.
      • Stuart F.
        • August 31, 1996
        • 4676
        The only problem I've had with the "water slide" decal is shelf life. I had a stock on hand and recently cleaned my covers while doing a valve adjustment. My existing "water slides" had been on for a number of years and were peeling at the edges. When I tried to use some new ones, they all broke up, I could not find one good useable one out of four, so ended up using the adhesive back type. Also, placement with the latter is much easier.
        Stu Fox
