small gas tanks - NCRS Discussion Boards
small gas tanks
  • Frank S.
    • March 13, 2011
    • 9
    small gas tanks
    are small gas tank on 63 corvette have hold down straps with a hook at one end nut bolt at the other end or is there any threaded holes in the rear frame
    • 6955
    Re: small gas tanks
    Frank, I just did my 63 chassis and the gas tanks straps are hooked on one end and the other side has a carriage bolt with nuts there are two nuts for each side one on the top the other on the bottom,
    The bottom nut is to adjust the tension on the strap, The the other locks the adjustment in place.
    • Frank S.
      • March 13, 2011
      • 9
      Re: small gas tanks
      so there no thread bolts in the frame from the factory that the small tank strap is bolted to thread into the rear frame
        Re: small gas tanks
        Frank -
        That's correct - there are no bolts at the rear of the straps where they hook into the frame; only bolts are at the front.
        • Frank S.
          • March 13, 2011
          • 9
          Re: small gas tanks
          i was told by someone there are factory thread tap hole near the rear frame which show a small tank was install by those threaded tap holes in the rear frame
            Re: small gas tanks
            Frank -
            Nope - no bolts at the rear, as shown in your Assembly Manual.
            • Wayne M.
              • March 1, 1980
              • 6414
              Re: small gas tanks
              Frank -- what you might be referring to is (on a 20 gal tank), the last clip nearest the rear where the rubber fuel line attaches to the steel line, there's a hole on the top side of the frame for a retention clip. [Ref. 1965 AIM UPC 8, Sheet B3, view A]. I believe the fuel line clip holes are pre-drilled on all frames.
              If you have a small tank car, the hole shown in the above reference will exhibit evidence of a screw having been threaded. If a 36.5 gal tank car, no thread evidence, and there'll be another hole for a fuel line clip at the cross-member inboard of the frame kick-up [Ref UPC N03, Sheet 4, view C]. This one will be threaded.
              I'd have to check my car for the UPC 8 hole theory, but it's too cold in the garage .
                Re: small gas tanks
                Frank -
                Here's the fuel line clip and screw on top of the right side rear frame rail Wayne referred to; that clip was used on all 20-gallon tank cars, and the hole for the thread-forming self-tapping screw was pre-pierced in all frames.
                • Frank S.
                  • March 13, 2011
                  • 9
                  Re: small gas tanks
                  when you were saying the screw was pre-pierced in all frames forming self tape hole all frame even z06 big tank car included
                  • Philip C.
                    • December 1, 1984
                    • 1117
                    Re: small gas tanks
                    Hi Frank the holes were there, but the hole should show no sign of a cut thread that a self tapping bolt/screw would make. Phil 8063
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      Re: small gas tanks
                      Another hole on an N03 car that should show no sign of a self-tapping threaded screw ever having been installed (this one is much easier to see): look on the passenger side frame kick-up just a couple of inches above the trailing arm pivot bolt. That's where the spiral-armoured fuel line is attached to the frame with a clip on a 20 gal car. On a tanker, that should be a clean hole.
                      The hole I'm talking about is the one shown in the thumbnail, from my late '65 20 gallon tank convertible.
