58 vacum cannister location - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    Does anyone have any good pics as to the exact location of the vac. can. relation to the bottle, would like to get it as close to correct if possible for judging, and do you need bothe vac, fittings for this to work, fitting at back center of carb and left rear hollow fitting that holds carb flange to manifold, 58 283/230 W.Washer System. Thanks, Brad.
