Idler pulley - NCRS Discussion Boards
Idler pulley
  • Dale C.
    • November 1, 1999
    • 844
    Idler pulley
    Dale
  • Dale C.
    • November 1, 1999
    • 844
    Re: Idler pulley
    Joe Lucia are you out there? I remember you talking about that idler pulley and its advantages, any thoughts on installing it with that repo bolt kit for the 69 and up?
    Dale
      • 43247
      Re: Idler pulley
      Dale
      Dale-----
      One BIG advantage of the idler pulley is that it eliminates the captive belt and makes it an adjustable-tension belt.
      Are you talking about installing the 1968-only idler pulley on a 1969 up big block? Actually, I like the 1968-only set-up better than the 69-74.
      • Dale C.
        • November 1, 1999
        • 844
        Re: Idler pulley
        Joe
        I have a 68 BB with A/C and the correct 68 pulley but am missing the lower attaching bolt. The repo's (long bolt) all look like they are for the 69 type pulley bracket that use that long bolt with that heavy duty sleeve. The 68 bracket conforms and butts up to the engine boss and would use a short bolt.
        Thanks for get back
        Dale
