SJ4653 Jack - NCRS Discussion Boards
SJ4653 Jack
  • Joe M.
    • April 30, 1990
    • 1343
    SJ4653 Jack
    How wide is the original jack base?
  • Greg M.
    • April 1, 1998
    • 119
    Re: SJ4653 Jack
    If no one else posts the measurement today, I will gladly measure mine tonight!
    Greg
    • Henry F.
      • April 1, 1979
      • 68
      Re: SJ4653 Jack
      Greg
      Like wise!
      Hank Fredella
      Vice Chairman Northeast Chapter
      Charter Member (1982)
      Webmaster www.necncrs.homestead.com
      • Joe M.
        • April 30, 1990
        • 1343
        Re: SJ4653 Jack
        Thank you gentlemen. I have a scissor jack that I purchased 20 years ago from JC Whitney. I believe the base is wider than the original and it is not fitting inside the spare tire properly.
        • David S.
          • December 1, 1982
          • 310
          Re: SJ4653 Jack
          Hi Joe,
          I just measured two jacks that I have. Both are the same measurements.
          7-1/8th X 3-5/16th
          Dave
          • Joe M.
            • April 30, 1990
            • 1343
            Re: SJ4653 Jack
            Thank you David. I don't have one original SJ4653 and you have 2! I am jealous! <grin>
            • Joe M.
              • April 30, 1990
              • 1343
              Re: SJ4653 Jack
              I need to saw off 0.65" from each side of the base. The threaded rod on the reproduction jack may be longer and therefore, the jack is not fitting into the spare tire rim as deep as the original. I might be able to cut off part of the end of the rod if necessary so the jack fits deeper into the spare tire rim.
              If one of you gentlemen could measure the threaded rod from tip to tip, that would be helpful. Thank you for your assistance.
              • David S.
                • December 1, 1982
                • 310
                Re: SJ4653 Jack
                Hi Joe,
                Measurement on the rod is 13-1/4"
                What is the length of the one you have
                Dave
                • Joe M.
                  • April 30, 1990
                  • 1343
                  Re: SJ4653 Jack
                  13-5/8". I cut off approximately 0.7" off of one side of the base and that helped problem. Will probable cut off 3/8" off of threaded rod so the jack sets down into the rim a little deeper. Thank you for the measurement.
                  • Henry F.
                    • April 1, 1979
                    • 68
                    Re: SJ4653 Jack
                    Joe & Dave, my jack measurers 7-1/8" long x 3-3/8" wide, minor difference!
                    Hank Fredella
                    • David L.
                      • July 31, 1980
                      • 3310
                      Re: SJ4653 Jack
                      Back in the late 1980's I bought a NOS SJ4653 jack at a swap meet in Shirley, MA, for $10. It was painted red with a sticker on it from an auto parts store (I forget the name), and came with a handle much longer then the 53-61 Corvette handle. Apparently this auto parts store chain bought their "universal" jacks from AUSCO and sold them with a much longer truck handle. The jack found a new home in Hawaii shortly thereafter. The jack was identical to the 53-61 Corvette jack.
                      I have some 57"+/- long Chevy truck handles for very cheap $ that could be converted to the 44.5" (I believe) 53-61 Corvette handles by someone with some welding talent.
                      • Rick G.
                        • March 1, 1983
                        • 276
                        Re: SJ4653 Jack
                        Hi David,
                        I believe the name of the auto parts store was Western Auto. You are correct about the color being the only difference. There was an article many years ago in the Restorer about it. I still look at every garage sale and swap meet for one.
                        • David L.
                          • July 31, 1980
                          • 3310
                          Re: SJ4653 Jack
                          Originally posted by Charles Gower (6398)
                          Hi David,
                          I do as well.
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11367
                            Re: SJ4653 Jack
                            Joe,
                            I had the same problem as you with a replacement jack, so I did what you did(or thinking of doing.....) years ago, cut off some of the threaded rod so it would fit inside the diameter the spare wheel........
                            Ooooooops! Big mistake silly me.....I got a flat tire in the rear one day, and went to put the jack under the rear axle. I forgot about one thing when I cut the threaded rod.........the jack cannot now be lowered enough because it ran out of threads. It's higher now.
                            I couldn't get it under the axle with the flat tire!........
                            I hope you don't run into the same issue. Best to check it'll still work with a flat if you cut the rod.
                            Rich
                            • Joe M.
                              • April 30, 1990
                              • 1343
                              Re: SJ4653 Jack
                              Excellent point Rich; had not thought the process through that far. Will jack up car first before cutting off rod.
