C1 Window regulator removal - NCRS Discussion Boards
  • Philip P.
    • February 28, 2011
    • 558
    Is there an easy way to remove the window regulator? I have all the documents ST-12 etc show and telling the procedure, but cannot seem to get it in the correct position to get it out of the door.
    Phil Porter
    1960
  • Paul M.
    • November 1, 1987
    • 142
    Re: C1 Window regulator removal
    Make sure the door post and lower channel are out. Them set the regulator for about 1/2 way. You should be able to look down where the glass goes and manuver it out. Good thing you don't have power windows.
    • Philip P.
      • February 28, 2011
      • 558
      I hate to sound stupid but does it come out the top, in the manual they have the glass help up by a block of wood. They don't have you removed the glass.
      Phil
      • Dan D.
        • November 5, 2008
        • 1323
        My 57 has power windows and I most likely will be taking the doors apart soon. Do you know how to do it? I have not looked in the archives yet. -Dan-
        • Mike E.
          • February 28, 1975
          • 5153
          I did an article on that about 25 years ago in the Restorer. Should be part of the Restorer DVD you can buy. Be careful of your fingers--don't remove the wrong thing.
          Mike Ernst
          • Paul M.
            • November 1, 1987
            • 142
            The regulator comes out the large hole to the back of the door. I always have the glass out as I am usually doing a complete restoration. The track that is below the post needs to come out or at least loosened up and pushed towards the outside of the car.
