69 Front Bumper Bolts - NCRS Discussion Boards
+ More Options
Posts
  • Wes G.
    • December 1, 1999
    • 99
    Does anyone have access to a 69 Standard Parts Catalogue which hopefully could provide me with sizing, dimensions, finish, possible head marking for the following 69 Front Bumper Bolts and washers:
    Part #'s:
    Bolt 9419075
    P. Washer 9419276
    L. Washer 103328
    Bolt 427559
    L. Washer 103321
    Bolt 9419077
    L. Washer 103322
    SPL. Washer 6256884
    Wes
    NCRS # 33239
  • Joseph M.
    • June 30, 1999
    • 334
    Re: 69 Front Bumper Bolts
    I don't have a Standard catalog, but what you need can probably be found from AMK bolts. They make a lot of fastners for various applications that have correct finishes, dimensions and headmarks. They have an online and hard copy catalog. You can also contact Richard Fortier. He sells vintage hardware and is quite knowledgable in this area. He advertises in the Driveline.
    • Chuck S.
      • April 1, 1992
      • 4668
      Part #'s:
      Bolt 9419075
      P. Washer 9419276
      L. Washer 103328
      Bolt 427559
      L. Washer 103321
      Bolt 9419077
      L. Washer 103322
      SPL. Washer 6256884
      Wes
      NCRS # 33239
      9419075: 7/16" NC X 1 1/4" Lg
      9419077: 7/16" NC X 1 1/4"Lg (Difference from 9419075 is not clear in notes)
      427559: 3/8" NC X 1 1/2" Lg
      These bolt part numbers in 70 are Gr 5 with M and A headmarks (three radial lines). From other posts here, I suspect these headmarks will work on 69s as well.
      All hardware is believed to have been black phosphate in 70. I should think the finishes would remain the same for same part numbers, but reports of zinc bumper bolts on original C3s persist...I can only tell you what was on ONE late 70.
      My observation has been that cut lock washers come in at least three different grades from light duty to extra heavy duty...keep the lock washers with the respective bolts, or match appearance if you replace.
