Valve Cover Gaskets - NCRS Discussion Boards
Valve Cover Gaskets
  • Dino L.
    • February 1, 1996
    • 694
    Valve Cover Gaskets
    On a base motor 350/300 1970.....What were the factory original valve cover gasket material and design? Who currently sells an accurate reproduction? If anyone has a pic of an NOS set, that would be extremely helpful.
    Also what were the correct bolt head and washer styles on those steel covers?
    Dino Lanno
    • 6956
    Re: Valve Cover Gaskets
    Dino, the bolts were hex heads, a common marking on the head was RBW there were rectangle washers under the bolts, there were a few other markings that would also be correct.
    The gaskets were a cork/rubber gasket sometimes in the 70's they had a silver coating on them which helped them adhere to the cover and head.
    Its are pretty rare to see a set of the coated gaskets, unless you find a nos set. You just buy a set of Fel pro v/c gaskets at any local parts store, just paint the edges orange, because when they painted the engine the orange overspray gets on the edges.
      • 11692
      Doc Rebuild sells a very nice set that doesn't have the extra "one size fits all" holes.
      • Larry M.
        • January 1, 1992
        • 2701
        I agree.
        Larry
          • 15632
          Ed,
          Small block rocker arm gaskets were silver coated? I knew Mark IV were, but silver coated small block RA gaskets are new to me. I keep learning new things from you guys.
            • 43277
            Ed,
            Terry-----
            If silver coated small block gaskets ever existed from GM, I never saw any.
            All the small block gaskets I have seen from GM were rubberized cork with no coating of any kind.
            There have been 5 different part numbers for small block rocker arm gaskets used for L1959-77 small blocks over the years. With the exception of the first, I do not know what the differences were:
            GM #3770632 (no extra holes for compatibility with pre-L59 heads)
            All of the following SERVICE all 55+ heads and are "dual upper holes":
            GM #3785640
            GM #3816380
            GM #3884080
            GM #3933964 (remains available from GM to this day)
            The gaskets used in PRODUCTION for the L1959-1977 heads did not have the "dual upper holes".
            • Dino L.
              • February 1, 1996
              • 694
              Is this the correct washer and bolt?
              Dino Lanno
                • 43277
                Dino------
                The retainer (washer) looks correct. I can't see the bolts well enough to say. The bolts on my original owner 1969 small block were trimmed head (i.e. "non-indented"), ungraded (i.e. no radial lines), and with a large "D" headmarking. I expect that other headmarkings were used, too, but I would expect that all would have been otherwise similar to the bolts I described.
                • George C.
                  • December 1, 1988
                  • 583
                  I've had these Valve Cover Gaskets sitting in my basement since the late 70's-early 80's. One bag still sealed and gaskets have broken apart. Opened other bag to give you a better look. Hope this helps.
                    • 43277
                    George------
                    The strange thing is that I cannot find that these GM #14082322 gaskets were ever cataloged for a Corvette, either originally or supercessively.
                      • 6956
                      Terry-----
                      GM #3785640
                      GM #3816380
                      GM #3884080
                      Joe, I thought I rememebered the gaskets were coated, In the 70's to the late 80,s I worked at at a Chev/Pont. dealership. Maybe I was thinking of the pont. engines having the coated gaskets. I know the Chev. big blocks had them.
                        • 43277
                        Edward-----
                        Yes, Chevrolet big block gaskets were coated with the silver sealer. I'm pretty sure that Pontiac valve cover gaskets were, too. However, I never saw a small block gasket that was. The GM #3933964 has been the gasket that has been available from GM to SERVICE small blocks since February, 1969 right through this day and I don't recall seeing any of these that were silver-coated.
                          • 43277
                          George-----
                          I've discovered something about these GM #14082322 gaskets. For one thing, they're still available from GM. For another thing, they lack the "dual hole" upper side configuration which makes the 3933964 gaskets applicable to both 1955-E59 as well as L1959-77. Plus, they cost about 3 times as much as the 3933964.
