62 Power Windows Connector - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 305
    I'm looking for a drivers side (5 wires) power window connector or some pins to repair a power window harness. I really only need 2 pins which I could salvage from an old harness.
    I also need a small retainer clip (would like to get one, I could epoxy it) that holds the switch into the chrome bezel.
    Any help out there ?
    Steve Gansky
    Newtown, (Bucks County) PA
  • Las K.
    • July 31, 2006
    • 96
    Re: 62 Power Windows Connector
    Stephen, are you looking for the pins which attach to the wires? If I'm reading your question correctly, the pins are still available.
    • Stephen G.
      • January 1, 2002
      • 305
      Thanks for the reply Las. I've managed to locate a complete connector from a harness that was scrapped. I have not received it yet but hope it's in good shape.
      I had one broken terminal inside the connector. The connector body was also overheated and had warped. I did also salvage some terminals from an old 88 harness. The 84-89 P/W (and some seat control) all use the same terminal but use a larger gauge wire (and different connector).
      The harness makers will not sell the P/W connectors or repair parts from the 61/62 cars but will sell the complete harness. It seems that for mid years up they do have repair parts and don't make you purchase the whole harness.
      Steve Gansky
