C1 steering wheel removal - NCRS Discussion Boards
  • Thomas H.
    • August 31, 2005
    • 1058
    I want to rebuild my steering box on the 60. The clutch head type screws that hold the horn button clip onto the steering column, don't look like typical clutch head screws. They have one side that has, what I would describe as, teeth. These teeth prevent my clutch head driver from seating properly. Before I booger up the screw heads, figured I'd ask if there was a special tool to remove these screws?
    Tom
    2007 Z06, Lemans Blue
  • John F.
    • March 23, 2008
    • 2408
    Re: C1 steering wheel removal
    Clutch head screwdriver of the right size should go right in. Mine worked. Also disconnect the battery.
    • Thomas H.
      • August 31, 2005
      • 1058
      John,
      There must be a size in between the ones I have that fits. I'll do some searching.
      You gave me a laugh when you mentioned disconnecting the battery. Made me realize I don't have one for the car, need to put it "on the list" to get. I'm still several months away from needing one though......
      Tom
      • Bruce B.
        • May 31, 1996
        • 2930
        Those are typical clutch head screws.
        If you don't have the correct size driver just grind a flat screwdriver to fit.
        • Thomas H.
          • August 31, 2005
          • 1058
          Another excuse to buy more tools!
          • Anthony P.
            • June 27, 2010
            • 485
            I picked up a set of bits on ebay a few months back and it had the right size for the wheel and was a nice set.
            here it is: http://cgi.ebay.com/ebaymotors/1955-...#ht_500wt_1165
            • Gary B.
              • September 30, 1987
              • 305
              Get a small bolt and grind the sides down to fit. Now you can use a socket wrench.
              • Bruce B.
                • May 31, 1996
                • 2930
                Go to your local swap meet and look for the guys with the chinese tools.
                I used to buy the set pictured in the previous post for anywhere form $5.00 to $10.00 and resell them on Ebay.
                They are actually very well made.
