Ignition Shield Wing Nuts - NCRS Discussion Boards
  • Jeff P.
    • 799
    Hey folks,
    I took off the shielding on the 68 L79. I'm going to give them a good cleaning and polish. I noticed a few wing nuts are squished at the wings from routine take offs with channel locks or similar pliers. I purchased a few years ago that look similar to the originals. Is there any noticeable markings I should be looking for on the originals ? Thanks as always , jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Gene M.
    • April 1, 1985
    • 4233
    Re: Ignition Shield Wing Nuts
    I think you will find the repro wing bolts are good as installed. If put side to side with an original there is a minute difference in size but not discernible otherwise.
    • Jeff P.
      • 799
      Thanks, Gene. Once and a while I see a wing nut stated as NOS on EBay and they go for good money. I guess that is the power of stating something as NOS. Jeff
      • Wayne M.
        • March 1, 1980
        • 6414
        Originally posted by Jeff Pollard (15573)
        ... I noticed a few wing nuts are squished at the wings from routine take offs with channel locks or similar pliers. I purchased a few years ago that look similar to the originals. Is there any noticeable markings I should be looking for on the originals ? ...
        Jeff -- I heard somewhere that originals have no evidence of the thread shaft end on the wing side -- as if the cavity was filled with "pooled" solder or some other metal. Here's a couple of mine that I believe are original for C2.
        • Jeff P.
          • 799
          Great pics Wayne . Thanks for your help. Jeff
          • Jeff P.
            • 799
            • Gary B.
              • February 1, 1997
              • 7078
              Jeff,
              A single wing nut that goes for $25 or higher on e-bay could be the wing nut for the air cleaner cover. Repros of those wing nuts are detectably different from originals, hence the high e-bay price.
              Gary
