Re-Use of Head Bolts? - NCRS Discussion Boards
  • Larry M.
    • December 1, 1986
    • 541
    In 1988, I rebuilt my 1972 350 engine, assembling it with new GM head bolts.
    In 17,000 miles since that rebuild, the heads have not been removed.
    I may be removing the heads later this spring. When re-installing the heads, can I safely re-use the existing head bolts, or should I replace them at that time?
    Thanks!
    Larry
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Re-Use of Head Bolts?
    Thanks!
    Larry
    as long as they "pull" torque you are OK
    • Larry M.
      • December 1, 1986
      • 541
      Clem,
      Thanks. Since they've only been torqued once, I would hope they have another 'pull' left in them.
      Larry
