Aluminum cleaing - NCRS Discussion Boards
Aluminum cleaing
  • Dick W.
    • 10483
    Re: Aluminum cleaning
    Originally posted by Domenic Tallarita (51287)
    Don,
    Makes sence but I'll bet they beed blast if they are going to tumble afterwards.
    I have a parts tumbler in the shop and it does not remove the black corrosion spots on the aluminum.
    My tumbler to small to put large parts in and we use walnut shells most of the time.
    I use the tumbler to polish parts (die cast) and give them the sheen they had when they were new and think that tumbling a sand cast part changes the original sand cast look.
    There is a acid we use on aircraft sand castings and skin, all aluminum with exception to anodized aluminum. It does a good job on cast and can be further treated with clear alodine which is a chemical not a paint, that slows or stops further corrosion.
    DOM
    W
    If you want to do the reskinning yourself, then invest in a Wheelabrator. I looked at buying one years ago, but, to me, it ain't worth $10-15k used. And that is just one part of the equation.
    I have restored cars and trucks for 50 years and there ain't no free lunch Ethel. Ya wants the looks, ya pays the bucks. I have two that I am working on right now, probably the last that I will ever do, and they ain't Vettes. You do not realize how lucky you are with all the repro parts available. I scrounge eflea, three forums, and a couple of other sites every day for parts and pieces. What repros that are out there for my vehicles are very poor.
    Dick Whittington
    • Mike E.
      • February 28, 1975
      • 5140
      Re: Aluminum cleaing
      No one has mentioned steam cleaning. A small restoration place near me uses aluminum cleaner and steam--he believes that it opens the pores of the aluminum. I've seen some intakes he has done--they're mighty nice looking. Valve covers okay, but not quite as nice.
      • Domenic T.
        • January 29, 2010
        • 2452
        #18
        That sounds like it might be a good way to use the acid and have it work better.
        The valve covers are cast differently and that may be why the are not as nice. I believe they are die cast and the surface is tighter than sand cast.
        DOM
        • Jim D.
          • December 1, 1994
          • 82
          #19
          Thanks for all the replys. That is the value of this site, love it. Here what I did to handle the valve covers. I bought a set of nos valve covers still boxed. Took them out and gently cleaned them with the suggested hand cleaner...look great. For $90.00 seemed to be a good way to go.
          • Dick W.
            • 10483
            #20
            He is using a mild phosphoric acid solution. I have done this to quite a few aluminum parts. Does a fair job, but not as new.
            Dick Whittington
            • David V.
              • April 30, 1991
              • 88
              #21
              Great thread. Thanks for the info guys.
              • Dick W.
                • 10483
                #22
                Be aware if you use phosphoric, use a mild solution. Too strong and it will turn the aluminum black.
                Dick Whittington
