Delco Coil - NCRS Discussion Boards
Delco Coil
  • Ray C.
    • June 30, 2001
    • 1132
    Delco Coil
    Is there a chart or source of information that provides the values-specifications for Delco coils? I am in need of a 107 coil for a 1961 FI project car. (reproduuction coil last resort) I have a few original coils that I have collected over the years and would like to know if they would be anacceptable replacement coil while I am on the hunt for an original 107 coil. I am assuming that the 107 coil provides a hotter spark for the Fuel Injected engine than the 091 coil that is used for the carbureted engines.
    Thanks for any information!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Doug L.
    • March 14, 2010
    • 442
    Re: Delco Coil
    Hi Ray,
    I don't have the information you are looking for but the "091" ignition coil was used on early '63s and the '64 365 and L-84 FI engine. I'm looking for one now for my L-84.
    Some parts catalogs will indicate the original Delco coil number their repro coil replaces. The LI Corvette catalog shows those references but the one I have is for C2s and does not show the 107 coil, You could look in their on-line catalog for 61 and 62 Vettes and maybe find the 107 referenced to verify that it is the coil you need. Ebay may have what you need but I have not seen that reference number.
    Best regards-Doug
    • Ray C.
      • June 30, 2001
      • 1132
      Ray Carney
      • John D.
        • November 30, 1979
        • 5507
        Re: Delco Coil
        Hi Ray, According to the Corvette Servicing Manual ST12 on page 14-14 the specs for the 097 and 107 are the same!!!
        Primary Resistance (ohm) for both is 1.00-1.16
        Secondary Resistance (ohm) is 7500-10,500. Go Figure. Meanwhile you may never find a real deal 107. Even 091's are drying up but not like the 107's. The 107 started off life in heavy equipment application. It was not a coil made just for the Corvette. School buses, etc in that era used the 107. This info came from Dale Pearman an eon ago. John
        • Ray C.
          • June 30, 2001
          • 1132
          Re: Delco Coil
          Thanks! John
          Just the information I was looking for!
          Ray
          Ray Carney
            • March 31, 1990
            Re: Delco Coil
            Remember, primary & secondary winding resistance specs are NOT the ultimate word. Those specs are there because that was something the average auto tech could easily measure. Plus, IF the coil was a basket case (one or both sides burned out), it'd show up when you measured/verified the winding resistance.
            Where the rubber meets the road is measuring primary/secondary inductance, mutual inductance and forward energy transfer. But, these measurments are generally over the head of your average multi-meter technician...
            • Philip C.
              • November 30, 1984
              • 1117
              Re: Delco Coil
              Ray
              Hi Ray, maybe its me, it seems everyone has got this idea that ITS got to be a 107 or 091 hell you could put a coil from a john deer in there and drive it. If you find a 50 year old 107 and pay 500.00 for it how good is it and how long will it last. Phil 8063
              • Ray C.
                • June 30, 2001
                • 1132
                Re: Delco Coil
                Hi! Philip
                The reason for my original post is to find an alternative Delco coil for my 1961 FI project; I will not pay high dollars for a 107 coil! But, I will stay on the hunt for an original 107 coil; the hunt is part of the fun of restoring an old car. The local junk yard just scrapped out a huge collection of old school busses last year and I believe these busses are a good source for the 107 coil. Knowledge is power and I wish I had known that an old school bus may have had the part I needed a year ago.
                Thanks for the post!
                Ray
                Ray Carney
