Pic of spring gap in '72 car - NCRS Discussion Boards
  • Douglas M.
    • February 25, 2011
    • 55
    Here is a pic showing the gap between the spring and differential bolts, all is believed to be original. Is this normal? or is something not stock?
    Doug
  • Edward J.
    • September 15, 2008
    • 6960
    Re: Pic of spring gap in '72 car
    Doug, the gap seems normal, although the how many leafs does the spring have? And do the end of the leafs curve up? it appears that there are not enough leafs from the pic. , The standard suspension had 9 leafs and the F41 had 7 leafs.( which would be rare for 72- ZR1 only)
      Doug -
      Are the four bolts 9/16"-12 or 7/16"-14?
      How wide (fore-aft) are the spring leaves?
      • Paul O.
        • August 31, 1990
        • 1716
        Doug looking at your photo it appears you have a later differential cover as John stated what size are the bolts and the spring width.
        Paul 18046
          • 43295
          Doug
          Doug-----
          Definitely NOT how it's supposed to be. You have a later cover which is designed for use with springs that are 2-1/2" wide and uses 7/16" bolts rather than the 9/16" bolts originally used for your application. It's very easy to confirm this by checking the casting number on the cover which is easily seen. If it's 464910 then you know you have the later cover.
          The later cover can be used with an original 2-1/4" wide spring as long as you also use the 7/16" bolts (which you already have), the later spring plate GM #457977 (which I would assume was used already), and two GM #459032 spacers. These were definitely not used in your case and that's why you have the space between the bolts and the spring. Unfortunately, these spacers are GM-discontinued but they can be fabricated or one could use 1/8" thick steel plates on either side of the spring.
            • 3422
            Hi Doug,
            Here's a picture of those bolts on my 71's rear std. suspension.
            The spring, mounting plate, bolts, and cover are the original parts; but the spring liners are reproductions.
            Hopefully you can get an idea from it of how close the bolts typically are to the spring.
            • Douglas M.
              • February 25, 2011
              • 55
              Hi Doug,
              Nice looking spring stack! Maybe someday my rear suspension will be as clean...
              My bolts are definitely 7/16" bolts, not 9/16"
              I will measure leaf width later today. I can easily fab up a spacer.
              Different subject: What would be original finish for my half shafts, and is there a particular paint that would duplicate that look? Same with the spring leafs.
              It appears to be a 9 spring stack, you just can't see the two short top leaves very well, the top one is maybe 8" long, and the second from top just somewhat longer.
              This car is going to be a piece or two at a time, body-on-frame resto, Replace half shaft U joints ASAP, and refinish half shafts before reinstalling. New exhaust system at same time
              Maybe rebuild rear spring in a few months.
              Doug
              • Gary B.
                • February 1, 1997
                • 7087
                Doug,
                If the top leaf is only 8" long, then it's not an original Corvette 9-leaf spring. The top leaf on original 9-leaf springs is 13" long, and it should have the taper rolled ends, just like the other leafs (except the main). If your top leaf is 8" long and if does not have the taper rolled ends, i.e., if it's completely flat, it could be a spacer plate that was used with some Corvette 7-leaf HD springs.
                Gary
                  • 43295
                  Doug
                  Doug------
                  Half shaft finish was natural steel for both the tube and yoke ends. You can use a good cast iron paint (like VHT high temperature cast iron paint) for a fairly natural appearance on the yoke ends. This will be detectable during judging but I think it's a worthwhile compromise for long term anti-rust durability. There is no paint you can use on the tubes that will look anything like the original finish.
                  • Douglas M.
                    • February 25, 2011
                    • 55
                    Top leaf/spacer is 10" long, and about 1/8" thick,and flat.
                    Second leaf is 14" long,a nd has curved up ends.
                    Spring width is 2.25"
                    Doug
                    • Terry B.
                      • August 31, 1999
                      • 607
                      Doug,
                      On your half shafts and drive shaft too for that matter, you could have them bead blasted and then sprayed with clear to prevent corosion. Mine have lasted 5 years with no rust yet. It gives a much more realistic look.
                      Terry Buchanan
                      Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                      Corvettes Owned:
                      1977 Coupe
                      1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                      2003 Electron Blue Coupe
                      2019 Torch Red Grand Sport Coupe
                      • Michael W.
                        • April 1, 1997
                        • 4290
                        Terry-
                        Doug's car is a small block which means that the half shafts were not shot peened. A bead blasting will reasonably replicate the BB look but won't look anything like the extruded tube surface finish of SB shafts.
                        Some guys have had the shafts re-tubed to replicate the appearance but then preserving it becomes an issue.
                        • Gary B.
                          • February 1, 1997
                          • 7087
                          Doug,
                          Bead blasting your half shafts will probably remove evidence of the longitudinal seam weld, which some judges will note.
                          Also, back to the spring. I measure leaf #2 to be 15" long on an original mid-year spring.
                          Gary
