1962 Exhaust manifold date code 3797901 - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    I am reading the JM section 12/page 61 where it talks about the Exhaust manifold dating and states:
    Exhaust manifolds (except original 1962 3797901 and 902) normally contain casting dates (month & day only) on inboard cylinder head side and .........
    Does this mean that 1962 manifolds do not have a date or have the month/day/year?
    I am looking at my manifolds and all I see on the back side is:
    3797901 = is 901 on one end and 901 over 942 on the other end
    3797902 = is 902 on one end and 902 over 942 on the other end. There is also a 1 by it self between the back 2 ports.
    Thoughts?
    Tony
    Re: 1962 Exhaust manifold date code 3797901
    If I remember correctly, date code emboss of these castings didn't start until sometime in the early '64 model year...
    • Jerry W.
      • January 27, 2009
      • 588
      No date cast on my original 62 exh.manifolds but I found the following.
      Under the casting number 3797901
      L H 2
      Under the casting number 3797902
      R H 2
      • Mike M.
        • May 31, 1974
        • 8400
        if i recall correctly, c-1 exhaust manifolds WITH date codes were manufactured in tonowanda for pass cars and the flint cast-manifolds for vettes and some pass cars of the era were lacking cast date codes.mike
        • Richard T.
          • February 1, 1979
          • 858
          Service replacement manifolds sold over the parts counter were dated. Assembly line 62 manifolds were not. Rich
          • Anthony P.
            • June 27, 2010
            • 485
            On the front side same as yours, except mine have RH1 and LH2
            L H 2
            R H 2
