427 Bypass Hose leaks... - NCRS Discussion Boards
  • John D.
    • November 30, 1979
    • 5507
    Re: 427 Bypass Hose leaks...
    Richard, Try Permatex Aviation Form-A Gasket Part No. 3H.
    Resistance to antifreeze. Good luck, JD
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11288
      Yes I've been using that for a long, long time. I did use that on this bypass hose too, but not the first time when it leaked. I still have to refill the cooling system and test everything, and ready to add the new heater hoses, etc. Hmmmm, good reminder. I'll put some on those too.
      Rich
      • John M.
        • December 31, 1999
        • 175
        #18
        Wittek #10 for bigblocks, Wittek #39 for smallblocks, I have NOS #10 clamps if needed........Thanks JOHN
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11288
          #19
          ....Learn something new every day. Thanks for the info John.
          Rich
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11288
            #20
            So after seeing John's info I've been looking at pictures of BB bypass hoses. Most I see have the clamp screw with almost all of the threads exposed on the side where the nut is. They look unusual that way.
            I went back to the Zip site and looked up the SB clamps. Those look smaller than the HC-614, their part described for the BB engines. The pictures may have been taken at different heights but it sure looks questionable to me. If the BB clamp is supposed to be smaller OD than the SB clamp, something appears reversed. I'll give 'em a call today to ask......Rich
            Here's the HC-614 BB clamp.....
            and here's the HC-614 SB clamp....
