1966 rear valence panel bolt or screw - NCRS Discussion Boards
  • Jack M.
    Infrequent User
    • December 31, 2005
    • 12
    does the rear valence panel attach with bolts or phillips head screws, i have been told are correct can someone help, which is correct for a 1966 coupe may build date. jack
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: 1966 rear valence panel bolt or screw
    Jack small bolts, check the 66 AIM, a 3/8 or 7/16 head size, I don't have my aim here.
    • Donald O.
      • May 31, 1990
      • 1575
      7/16" head size with a captive flat washer.
      DonO
      • Rich P.
        • January 11, 2009
        • 1361
        Jack,
        7/16" head special thick and wide captured washer. Headmarking EL, ELH with 2 or 3 circles.
        Rich
        • Rich P.
          • January 11, 2009
          • 1361
          One last picture to show the side.
          • Alan D.
            • December 31, 2004
            • 2025
            Jack, These should be called out in 66 AIM Section 1, sheet F3 dated 5/16/66
            Believe the pn is 9418710 however you will need to check since I have marked it two different ways. Have pictures of that pn if needed and if its the same for the 66
            Another one will be the two lower screws, lw, & nut. So check the pn for these also!
            • Rich P.
              • January 11, 2009
              • 1361
              Side bolt and nut. Sometimes they used a bolt with a recessed head and captured lock washer. The special flanged nut could be blank or have either a E or RBW marking.
              Rich
              • Rich P.
                • January 11, 2009
                • 1361
                Picture in last post did not work here it is
                  • November 30, 1997
                  Richard Fortier makes the special flanged nut, and has the bolts too.
                  • Ronald L.
                    • October 18, 2009
                    • 3248
                    Make sure you get the 66 head mark, they were not the same for all years.
