Side window front channel - NCRS Discussion Boards
+ More Options
Posts
  • Jim D.
    • 2884
    Does anyone make correct front channels for a coupe (1965)? As you can see by the pics. below, the ones I received are quite different in size. They won't sit in the channel low enough for the two top clips to retain them and if forced down, the beads collapse into the channel instead of sitting on top like they should. Hopefully they are all not like these ones. Thanks in advance.
    New one on the left
    New one on the right
