Does this engine stamping look correct? - NCRS Discussion Boards
  • Dave B.
    • February 7, 2011
    • 20
    I don't see anything in the scrapings that reveals any swirl marks so I'm assuming the broaching is original. I believe this to be original and correct but would like a second opinion.
    Thanks!
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: Does this engine stamping look correct?
    No one here can provide a reasonable opinion on a painted pad. That is why the pad must be free of paint when presented for judging.
    • Dave B.
      • February 7, 2011
      • 20
      Fair enough, what are your thoughts on the size, placement and sequence of the stampings? Paint or no paint the numbers are very visible.
      • Dick W.
        • 10483
        I would be VERY leary of any pad that has paint on it. Correct characters are easy to come by, pad surface is almost impossible to duplicate
        Dick Whittington
          • 3415
          Hi,
          Did some engines escape without a broadcast code as part of the identification stamp?
          • Claus S.
            • December 30, 2010
            • 414
            On a 64 is the partial VIN first and the suffix to the right on the pad?
            Opposit to the stamp on the picture.
              Hi,
              Alan -
              The two-digit suffix (if that's what you mean by "broadcast code") on the engine plant stamp was included in the gang-stamp holder.
                Roger -
                The pad in the photo is a big-block; their stamps were reversed on the pad. Big-blocks had the engine plant stamp on the outboard side of the pad and the assembly plant VIN derivative stamp on the inboard end, and small-blocks were the opposite way.
                • Michael W.
                  • April 1, 1997
                  • 4290
                  Dick's right. The paint is covering up the 'critical' bits. You mentioned 'scraping' in your post. Best not use any metal or abrasive objects to clean a pad, this may damage or obscure the actual surface markings.
                  • Claus S.
                    • December 30, 2010
                    • 414
                    Thanks.
                    Roger -
                      • 3415
                      Hi John,
                      Shouldn't we be seeing those 2 letters?
                      • Dennis S.
                        • April 1, 2004
                        • 228
                        The Tonawanda stamp reads T 1012 IO
                        1012 is for October 12
                        IO is for L68 auto in 1968
                        maybe a "1" was used for the "I" but hard to tell with the paint
                        Dennis
                        • Michael W.
                          • April 1, 1997
                          • 4290
                          Hi John,
                          ?? I sure see them........
                          T1012IO
                          • Kenneth B.
                            • August 31, 1984
                            • 2087
                            Dennis
                            I agree. I don't see the small flag on the 1 or crosses on the I but it might be the paint. That is why there needs to be no paint on the pad. FYI the other guy I have looked at what the owner of BB Corvettes swear that the motor was original that had the SN under the plug & the build date to the top of the pad. So much for honest owners. LOL
                            KEN
                            • Dick W.
                              • 10483
                              If I were doing the inspection on this car and the seller refused to remove the paint, I would call the pad suspect, at best. If you cannot see the bare pad surface you cannot make an accurate call.
                              Dick Whittington
