62 Rocker Moulding Bolts - NCRS Discussion Boards
  • Christopher R.
    Infrequent User
    • January 1, 2001
    • 9
    I am trying to correctly mount the rocker moldings on a 1962. The bottom of the aluminum molding and the vehicle body both have (8) holes, but the mount kit only contains (5) bolts. Which holes are skipped? Thank You!
  • Terry D.
    • May 31, 1987
    • 2698
    Re: 62 Rocker Moulding Bolts
    Chris, where did you get the kit? The set I got from Dr. ReBuild had 8 pieces.
    • Anthony P.
      • June 27, 2010
      • 485
      Chris,
      None should be skipped. Note that the 2 closest to the front on both sides also go through the splash pan as well. I do not have my AIM handy, but there is a diagram in there sowing the mounting, including the order of he washers
      Tony
      • Christopher R.
        Infrequent User
        • January 1, 2001
        • 9
        I got the kit from Corvette Central. I saw the diagram in the AIM showing the lock/flat washer placement and it says to drill (5) holes, which is why I assumed the (5) bolts from the kit I have were correct. Thanks for the information, my question has been answered!
