Missing Piece - NCRS Discussion Boards
Missing Piece
  • Jack A.
    • March 1, 2001
    • 129
    Missing Piece
    Hi Guys,
    Well, I am in trouble again. I am almost finished with restoring my 61 F.I. car! Ran into a problem maybe you can help me with. I found out I am missing a Lisence Plate holder for the rear of the car. It goes inside the recessed cavity for the Lisence Plate. I have looked at most of the normal suppliers I go to, and can't seem to find it. Any ideas?
    Jack Alexander 35730
  • Terry D.
    • May 31, 1987
    • 2697
    Re: Missing Piece
    Jack
    Who told you it is missing? What is it suppose to look like? Are we talking outside the fiberglass? Can you post a picture of what your plate area looks like now with a description of what you think is missing cause I for one can't picture what it is you are missing?. Between the Chrome surround is two holes at the top to mount the plate and a bumper on the bottom to keep it from rattling. Now the 56-60's had a T-bracket that held the plate, but not 61-62.
    • Mike M.
      • May 31, 1974
      • 8405
      Re: Missing Piece
      the black stamped steel plate that bolts to the body(connecting to the bumper braces) isn't available as a repo to the best of my knowledge. i had to buy one from a friend for the 62 i'm currently doing. mike
      • Jack A.
        • March 1, 2001
        • 129
        Re: Missing Piece
        Hi Terry,
        Nice hearing from you again. You have helped me many times. What you describe is what I now have. The Tech manual however shows a bracket that is black painted metal that basicaly follows the countours of the recess . The Lisence fastens to it. I have seen one on a 62 that is in the restoration shop where my car is being finished up. I believe you first install the Lisence light fixture then this piece. Lastly the Stainless surround goes on. The guy that has the shop is a NCRS judge. James Ranahan. He pointed it out to me. Now unless he is wrong and there is one on the 62 and not on the 61 maybe, that is the answer. He could be wrong. I can possible get a photo later.
        Jack
        Jacn
        • Terry D.
          • May 31, 1987
          • 2697
          Re: Missing Piece
          Mike
          Is this the piece behind the fiberglass?
          • Jerry W.
            • January 27, 2009
            • 588
            Re: Missing Piece
            see pix 62 bracket
            • Mike M.
              • May 31, 1974
              • 8405
              Re: Missing Piece
              Originally posted by Terry Deusterman (11486)
              Mike
              its the metal plate that is sandwiched between the fiberglass and the license plate and its surrounde3d by the chrome plated "horseshoe" license protector. its overtop the licensce plate.mike
              • Jack A.
                • March 1, 2001
                • 129
                Re: Missing Piece
                Yes the photo and description is correct. GM lists the part # as 3776065. It is found in the 61 Service manual in section 14 page 3.00 It is in the 62 Manual also.
                • Richard T.
                  • February 1, 1979
                  • 858
                  Re: Missing Piece
                  The stamped steel plate support is not reproduced but they show up on e bay frequently. it's 61 62 only so if you keep an eye on those two years I'll bet you will find one. Good luck Rich
