Re: Small Block Rocker Arms
if the head has the double "D" shaped push rod guide hole you have to enlarge it so you do not get a bind because you are trying to align 3 points,the push rod guide hole in the head,the stud and the groove on the rocker tip on the valve stem. also you have to remove the bolt on guides if the head has them
