Big Block Rocker Arm Configuration - NCRS Discussion Boards
  • Larry T.
    • May 15, 2007
    • 404
    I am in contact with someone about purchasing a set of rocker arms. The ones I am looking at have the "L" marking and they are supposed to be originals of part #3860308.
    The same person has a set that he says are "the Heavy Duty Rocker arms/nuts/balls/studs and top lockers, "F" Marking at the end of the rocker."
    Can anyone shed some light on the rockers with "F" markings, I am not familiar with these.
    Thanks.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Big Block Rocker Arm Configuration
    Thanks.
    "H" marked are the best from chevy
      • 43242
      Thanks.
      Larry------
      The GM #3860308 are good rockers. They were used for 1965-E1969 SHP big blocks, including HD (L-88). They were replaced by the GM #6258611 in November, 1972. The 6258611 were discontinued some time ago, too.
      However, as clem mentions, the "H" stamped rockers, aka GM #3959182, are the best. These were originally used on later 1969 L-88, all ZL-1, and 1971 LS-6. These are still available today in a unit which includes the 3959182 rocker arm + rocker ball and nut and known as GM #12368082. A kit of 16 of these is available under GM #12368085 and GM lists for less than 100 bucks. So, why pay likely more than that for a set of the old 3860308?
      • Larry T.
        • May 15, 2007
        • 404
        Thanks Joe. I have the "H" rockers on my car right now. The reason I am looking at the "L" rockers is they just seem hard to come by and were original equipment for my L72 engine.
        Do you have any idea what the rockers with an "F" are? I am trying to get a picture and will post if I do.
          • 43242
          Larry------
          I don't ever recall seeing any "F" stamped rockers. I've seen "Z", "M", "X". It's possible that the "F" were the non-SHP rockers, GM #3860305.
          • Ronald L.
            • October 18, 2009
            • 3248
            I asked this in a similar way a while back...
            Were the M rockers used originally on the 66 427? 390HP???
            • Clem Z.
              • January 1, 2006
              • 9427
              why would anyone want inferior rockers on their engines when the 182 (H) are still available ???
                • 43242
                Ron-----
                I don't think so but I would not rule it out. 1966 L-36 used the GM #3860305 rocker arms. These are the arms that I do not know what character was stamped on them.
                I do know that the "M" stamp was used on the GM #6258611 rocker arms. These were released about 1972 and became SERVICE for 1966 L-36 but were never originally used on the 1966 L-36 application. However, it is possible that there were other predecessor rocker arms that used the "M" stamp. I doubt it but it's possible.
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  Thanks Joe, I'll go with they were replaced in 1975-6, they look new with very little break-in wear. If I recall, the original 427's for this time period did not have the slotted ball. These M's do....
                  • Larry T.
                    • May 15, 2007
                    • 404
                    Here is a picture of the rocker I was told had an "F". I am not sure I would call this an F. Does anyone recognize this part?
                    Larry
                    • Bill M.
                      • April 1, 1977
                      • 1386
                      I have a rocker arm from a '67 L78 that has no letter.
                      • Joe R.
                        • May 31, 2006
                        • 1822
                        Bill,
                        Did you mean to say 65 L78?
                        Joe
                        • Bill M.
                          • April 1, 1977
                          • 1386
                          Originally posted by Joe Raine (45823)
                          Bill,
                          Joe
                          Joe:
                          My post was very unclear. What I should have said was that I have an early rocker arm with no letter on it...
                          My '65 has an L78 out of a '67 Camaro. The heads are '68 rectangular port, the intake manifold an L72(?). It's a mutt.
                          Bill
                          • Wayne M.
                            • March 1, 1980
                            • 6414
                            FWIW, I have a set of rocker arms, springs valves, guides out off of oval port '68 heads # 3917215, dated A 68. No stampings.
                            Looking at the service catalogs (P&A30 series), the first time a stamped letter is referred to is in the Oct 1 '66 (1st issue 1967), with an "X" indicated for the hi-perf rockers # 3860308. Nothing for the lo-horse versions # 3860305.
                            Then My July '69 Rev. P&A30 says Z or L stampings for the ..308. Same thing in a Rev 10-1-69 catalog. And same again in Rev 1-1-70 catalog.
                            • Ronald L.
                              • October 18, 2009
                              • 3248
                              I would appreciate the source you have to get this GM set as indicated for about $100...
