I noticed leaking break fluid from the front right wheel of my base engine 67. I pulled the tire and confirmed the leak so I need to repair the breaks (either myself or with much more $$$$ by someone else) I need a little advice here. As background I have a 60 and have no fear of those breaks - rebuilt them several years ago - have been dealing with break shoes since high school - but I have never re-done disc breaks - so I do not have any idea how difficult this is)
Anyway - I checked the caliper numbers and the calipers seem to be from a mixture of numbers with most being 547xxx so it seems that originality is not an issue here. Car had a frame off by orig owner (as a driver) before I purchased from a friend so I suspect breaks were "sleeved" but how would I know for sure (orig owner is no longer around to ask)? How hard to rebuild? When I look in the repair manual it talks about special tools (J-22591, J-22592, J-22638 and the catalogs sell special spreaders and clips for the job) Do I need all of this? Do I need to turn the rotors (they look nice and smooth to me). Are the calipers worth anything or should I return for core charge if I replace? I just want an idea of what I am getting into here. If I need to have it done by a "shop" so be it - right now I can drive it over there and save a lot of time - I would rather do it myself because that is most of the fun of an old car - but I don't want to get it all apart and then have to have it towed in and be finished by someone else - that would probably cost more time and money. Any help or advice here would be greatly appreciated. Thanks,
Joe Utz
Joe Utz
The only other way I know of to correct runout of the rears is to shim between the rotor and hub. A buddy recently used thin aluminum sheets made up as shims to get it in spec. Beer cans were just the right thickness the last time he did it!
