1982 Cruise Control Issue - NCRS Discussion Boards
+ More Options
Posts
  • Dennis F.
    • October 28, 2010
    • 5
    My recently resurrected 82 (35,000 miles) has displayed an interesting problem when you set the cruise control. Once set, it very slowly continues to accelerate. Not something that is immediately attention-getting, but once you're paying attention to it, it's obvious. Set it at 60, and watched it slowly creep to 80 in 5 minutes or so. Even going downhill you can feel a slight acceleration.
    Any ideas? Vacuum leak? Transducer? Servo? Any adjustments rather than replace parts?
    Dennis Fisher
  • Pat M.
    • April 1, 2006
    • 1579
    Re: 1982 Cruise Control Issue
    Interesting problem Dennis. I'll give your post a bump, someone should be able to offer suggestions.
    • Dick W.
      • 10483
      My mind is a little foggy, but there is an adjustment to take care of that problem. I believe the adjustment screw is in the vacuum connection from the engine. It should have a slotted screw in there. I do not remember which way you need to turn it, but I do not think that it take much either way to make quite a bit of change
      Dick Whittington
      • Dennis F.
        • October 28, 2010
        • 5
        Thanks, we'll take a look at that.
          • 6950
          Dennis vac. port C on transducer is where the adjustment is. But make a few other checks first, vaccum hoses and make sure the speeo. needle is not jumping around, possible binding cable or kinked.these will cause problems with speed fluctuations.
