Ignition Switch Installation - NCRS Discussion Boards
  • Don Z.
    • August 31, 1998
    • 254
    I had my ignition switch out for work to be done on it by Peter Lindahl. I am now trying to re-install it. There is no excess wiring hanging there and no room for hands to get behind the switch to put the plug in + install the light bulb. The emergency brake is there and I have 4 way flasher unit on top of the emegerency brake bracket. Has anyone "been there, done that" before and can shed any light on this hopefully easy solutuion to plugging the unit in??
    Any help appreciated.
  • Mike M.
    • May 31, 1974
    • 8400
    Re: Ignition Switch Installation
    plug it in the switch before installing the switch in the housing.mike
    • Don Z.
      • August 31, 1998
      • 254
      Mike:
      I probably wasn't clear what I am trying to do. I do not have the switch in the cluster. I am trying to find a way to get the room so I can push the plug onto the switch along with the bulb socket.
      Thank You
