Identifying a 53 frame - NCRS Discussion Boards
  • John S.
    • December 31, 1997
    • 81
    How do you identify a correct frame for a 53 corvette? By numbers stamped in it or what. If so what are the correct frame numbers? Thank you.
  • Russ U.
    • March 31, 2004
    • 345
    Re: Identifying a 53 frame
    Frame stamping is a good way to tell a 53 frame - but frame stamps can be duplicated, so you are always in a buyer beware situation.
    The gas and brake lines ran down the outside of the frame on the passenger side on 53s and I believe early 54s. On later 54s, the lines went thru the X-frame, without cutouts on the passenger side of the X (in addition to the muffler pipe cutouts) allowing the lines to go thru. So you want to make sure that there are no cutouts or patch jobs on the X frame as well.
    The attached pic shows where the frame stamps should be on a 53. The stamp should read E53F001XXX, with the XXX being the serial number of the car. So, my 53 reads E53F001276.
    Hope this helps,
    Russ
    53 #276
    www.earlycorvettes.com
    • William C.
      • May 31, 1975
      • 6037
      Also, 55-up frames have a clearance area for the Fuel pump on the V8 that the early frames do not have.
      Bill Clupper #618
      • John S.
        • December 31, 1997
        • 81
        On the picture you sent, where is the frame stamp. Is it the black area on the side of the frameor where? Thank you for the info.
        • Russ U.
          • March 31, 2004
          • 345
          The orange pieces of tape are where you will find the frame stamps on a 53.
          • Troy P.
            • January 31, 1989
            • 1279
            Thanks for the education Russ. I'd forgotten the 53 stamp was in a different place and put down twice. I seem to racall now that Noland addressed this in Vol. 1.
