'65 BB assy. stampings (factory or rebuilder ?) - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    This thread is to solicit opinions on the oil pan rail stampings found on my mid-May '65 396 block. Previous threads discussed cylinder number stamping on the rods and caps. (Ref. https://www.forums.ncrs.org/showthre...84516&uid=5973)
    Driver side: Cyl. 1 stamped "9 (with underline)"; Cyls. 3, 5, 7 all stamped "7".
    Passenger side: Cyl. 2 (same "9" as cyl. 1); Cyls. 4, 6 8 all stamped "10".
    Large auto-load pics show Cyl #'s 1, 7 and 8, respectively. [to show each of the 3 different stamped digits]
    4 thumbnails show cyls 3, 4, 5 and 2, respectively. Number 6 was also a "10" but too weak for a good pic.
    So, you eagle-eyes , were these stampings to indicate piston size required at Tonawanda ? Or, are they some bozo re-builder with a nice set of dies ?
    BTW, nice broach marks, eh ?
    • 15621
    Re: '65 BB assy. stampings (factory or rebuilder ?)
    I vote "Tonawanda's best work"
    Outstanding broach marks -- just what one would expect.
      Wayne -
      Typical pan rail stampings denoting bore size, created in the block air-gaging station at the head end of the assembly line, and teleprocessed to the Piston Department to make up the piston/rod assemblies for that particular engine.
      Yup, nice broach marks .
