62 Turn Signal Lever - NCRS Discussion Boards
  • Roger B.
    • June 30, 1991
    • 82
    1. what color is the end of the original 62 turn signal?
    2. Why does the lever not go all the way into the body?
  • Roger B.
    • June 30, 1991
    • 82
    Re: 62 Turn Signal Lever
    Roger Behrens (19514);538549]
    • Bruce B.
      • May 31, 1996
      • 2930
      Roger,
      The end of the 62 turn signal lever is white and it has ribs on it.
      The lever has a wide nut on it so you put the nut on the lever, screw the lever into the turn signal mechanism untill it bottoms then tighten the jam nut.
      • John F.
        • March 23, 2008
        • 2396
        Two different 62 turn signal levers with locking nut. Car#10975 & #00029. I hope this is what you were looking for.
        • John T.
          NCRS Financial Officer
          • January 1, 1983
          • 291
          Also. The chrome locking nut has a chrome washer under it.
          Hope this helps.
          John
          • Roger B.
            • June 30, 1991
            • 82
            Is the locking nut on the treaded end of the turn signal.
            Does the end of the turn signal have a white grip?
            thanks
            Roger
            • Bruce B.
              • May 31, 1996
              • 2930
              Yes and Yes.
              • Roger B.
                • June 30, 1991
                • 82
                Thanks to all for the advise.
                Roger
