64 engine id help - NCRS Discussion Boards
64 engine id help
  • Ryan B.
    • February 1, 2011
    • 28
    64 engine id help
    I looked at where the in stampings should be, but it is smooth. No markings at all. I did find some other markings on the motor. Will they tell me anything about the block? Thanks - RB
    • 6954
    Re: 64 engine id help
    Ryan, Theres a part# on the drivers side rear of block. add that in, maybe someone can help. the date on pass rear looks like Mar. 15, 67.
    • William C.
      • May 31, 1975
      • 6037
      Look on the opposite side of the numbers you pictured at the rear of the block, and there should be a number beginning with a 3------- What is that number? The seven in the casting date indicates 57 or 67, which pretty well rules it out for use in a '64 Corvette as an original installation
      Bill Clupper #618
      • Ryan B.
        • February 1, 2011
        • 28
        I will be at the car again next weekend, i will take a look on that side. as i recall, the trans kickdown bracket was installed over some numbers i might have to remove that for a clear view. Thanks - RB
        • Dale M.
          • December 27, 2007
          • 386
          Ryan, I have a '64 and the number on the left side you should be able to see it just behind the shielding for the spark plug wires. This is the casting number. My car is 3782870 with a casting date of C124 (March 12, 1964). I would believe that the casting information should have been there when the casting was made. If the number is not there in front of the right head, then it may have been machined off or never stamped. I am not sure why it would have never been stamped, but likely not built into a car, like a short block or something like that. Good Luck on your research.
          • Paul J.
            • September 9, 2008
            • 2091
            All blocks were stamped. Ryan's block is not original to the car.
