power steering pulley - NCRS Discussion Boards
  • Craig O.
    • July 31, 1983
    • 207
    I have to replace the PS pulley on my 67 L79 AC engine, the bent one reads 3770509 CE and GM5 in separate locations on the front. It also has a woodruff key. no info in the judging manual. have some confusion on the proper pulley. Is this the right one?
    • 43258
    Re: power steering pulley
    Craig------
    Yes, it's the correct one for a C-60 application (but not a non-C-60 L-79). All 1963-74 Corvette power steering pumps used a tapered shaft with a woodruff key.
    • Neal K.
      • October 31, 2007
      • 305
      Joe,
      What does the 3770509 power steering pump pulley for an L79 with C60 look like? Is it the pancake style or the cast iron spoke style?
      Neal
        • 43258
        Originally posted by Neal Kalis (48092)
        Joe,
        Neal
        Neal------
        It's stamped steel, "pancake" type. It's the same pulley used for 300 HP with power steering.
        • Neal K.
          • October 31, 2007
          • 305
          Joe,
          Thanks for your reply. The AIM UPC N40 page A6 was a little confusing to me. The diagram depicts the cast iron 3 spoke type with 3 different pulley part numbers listed. I had boiled it down to the L79 with C60 using the 3770509 P/S pulley and that that pulley was the pancake type but wasn't sure I was right. Based on your reply I think I have it correct for my application.
          Thanks again.
          Neal
