1960 Fuel Line Routing - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2589
    I need some help. When I took my car (1960) apart, the fuel line at the rear was definitely not routed correctly. If anyone has pictures I would appreciate them either posted here or to my email (dharris45@aol.com).
    I have included a scan of the AIM where it looks like the line simply routes around the rear body mound tab then up to the tank on the outside of the frame (Red arrows).
    I also have pictures, thanks to Jerry Weeks, of a 1962 completed chassis. The fuel line on the 62 has a clip and screw on top of the frame at the rear body mount tab (see second picture).
    I assume there must have been a change in either 61 or 62. Could someone please confirm that the AIM is correct?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Jerry W.
    • January 27, 2009
    • 588
    Re: 1960 Fuel Line Routing
    Don.....Here's a pic of the original fuel line routing on our 62....before resto
    • Donald H.
      • November 2, 2009
      • 2589
      Thanks Jerry. both this and the other pictures of the finished frame you sent my show that the 62 fuel line goes up in front of, and over the rear body mount tab, and there is a clip screwed into the frame holding the line. My frame does not have the screw hole in the frame.
      Don Harris
      • Donald H.
        • November 2, 2009
        • 2589
        Any 58-60 restorers out there who can comment on the correct routing?
        Don
        Don Harris
        • William C.
          • May 31, 1975
          • 6037
          Have you checked Section 8 sheet 1 of the '60 AIM? It shows the line going around the body mount and the a union connecting to a pipe from the tank, if I'm reading it properly.
          Bill Clupper #618
          • Donald H.
            • November 2, 2009
            • 2589
            Yes, I actually attaced the AIM page above. I agree that is what it looks like. Just wanted some confirmation from someone rather than rely on a drawing that isn't exactly clear.
            Don Harris
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11364
              Don
              Don, Here are some from the Feb built '59 I'm doing, with a before shot after I pulled the body. Body never off before. I'm pretty sure the same setup for '60.
              Rich
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11364
                more pics with the tank line connected.....
                • Joe M.
                  • February 1, 2005
                  • 590
                  original fired 1960
                  • Donald H.
                    • November 2, 2009
                    • 2589
                    Rich and Joe,
                    Thanks, that's what I was looking for.
                    Don
                    Don Harris
