Carpet flaps - NCRS Discussion Boards
Carpet flaps
+ More Options
Posts
  • Karl K.
    • November 17, 2008
    • 92
    Carpet flaps
    Looking for he proper way to cut the flaps that cover
    the seat anchors in my 65 coupe? Also the carpet I took out had strips of
    carpet cut out under the seat tracks, is that correct or
    should there just be holes in the carpet for the front
    bolts?
    Karl
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 990
    Re: Carpet flaps
    Karl. The seat track does not sit on top of the carpet. The factory cut out the carpet and padding so that the seat tracks sit directly on top of the fiberglass. I've posted some photos of factory carpet cut outs from an original '65 convertible (the same technique used for both coupe and convertible).
    This should help.
    Good luck.
    Tony
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
    • Karl K.
      • November 17, 2008
      • 92
      Re: Carpet flaps
      Thanks Anthony,
      That's a big help.
      Karl
      • Karl K.
        • November 17, 2008
        • 92
        Re: Carpet flaps
        Hi Anthony,
        Are there supposed to be carpet flaps covering the rear mount brackets
        or just covering the front part of the seat track?
        Karl
        • Ray G.
          • May 31, 1986
          • 1189
          Re: Carpet flaps
          This should help.
          /Users/corvetteclassic/Desktop/zzz.carpetcutdiagramcrsmallmt0.jpg
          Ray
          I hope you dance
          • Tony S.
            • April 30, 1981
            • 990
            Re: Carpet flaps
            Karl. The rear attachment does not use a flap--only the front rail. The rear cut out exposes the bracket where the rear seat rail slides into it. The flap is only at the front mounting point.
            Tony
            • Karl K.
              • November 17, 2008
              • 92
              Re: Carpet flaps
              Thanks Again For The Help.
              • Scott S.
                • September 11, 2009
                • 1961
                Re: Carpet flaps
                Originally posted by Ray Geiger (9992)
                This should help.
                Ray
                Hi Ray,
                Could you check that link please? It's not working when I copy and paste it into the browser address box.
                • Ray G.
                  • May 31, 1986
                  • 1189
                  Re: Carpet flaps
                  Originally posted by Scott Smith (50839)
                  Hi Ray,
                  Hello Scott;
                  Try This
                  /Users/corvetteclassic/Desktop/carpetcutdiagram.pdf
                  Ray
                  I hope you dance
                  • Scott S.
                    • 1961
                    Re: Carpet flaps
                    Hello Scott;
                    Try This
                    Ray
                    I think it requires some kind of "www." prefix, or at least "http:/" prefix, I'm not able to connect to anything beginning with "/Users", unless I'm doing something wrong.
                    • Ray G.
                      • May 31, 1986
                      • 1189
                      Re: Carpet flaps
                      Hello Scott;
                      I should have used this attachment from the beginning.
                      Hope this helps w/ your original question.
                      Ray
                      I hope you dance
                      • Tony S.
                        • April 30, 1981
                        • 990
                        Re: Carpet flaps
                        Ray. You need to make one correction to your 63-66 cut out diagram. You show a dotted (uncut) line on the forward flap edge. That should be a solid line since it is cut. The flap has 3 cut sides and one uncut (hinge) side.
                        Tony
                        • Scott S.
                          • 1961
                          Re: Carpet flaps
                          Hello Scott;
                          Ray
                          Ray,
                          Thank you!
